Corian work surface
russellhrussellh Member Posts: 155 ✭✭
does anyone know the code/ name of my corian work surface?
    Looks correct to me.
    I just found mine, looks like sahara.  They offer to buy samples.  Too bad the largest sample is 10" x 10".  I need one to cover my cockpit sink.
  • russellhrussellh Member Posts: 155 ✭✭
    That's exactly what I want it for. Thanks for the help
  • partlowrpartlowr Member Posts: 119 ✭✭
    edited April 2016
    Your best bet would to be to find a Corian dealer in your area and see if they have scrap pieces. The vast majority of this stuff is used on kitchen counters and they obviously have to cut out the portion for the kitchen sink which is virtually unusable. Throw them $20 and have them cut it to your exact size and put a nice beveled edge and radius the corners.  There is a granite company down the street from me and I have had them cut me a piece of their scrap granite to cover my basement bar sink and a larger piece for my outdoor gas fire table which covers the burner and makes for a nice usable cocktail table when not in use. For my basement bar sink I actually had them cut two pieces, one that was about an inch smaller then I used construction adhesive to bond them together and now it fits down into the sink. I think that would be ideal for the boat considering it is always going to be moving and the cover will never slide out of place....it would also make for a fancy cutting board or cheese board.
    Good luck
    That's a good idea thank you. I've got a dealer nearby
