Starboar shifter stuck in forward gear. !!
sdjavalina
Posts: 32 ✭✭
Was out running around , think i pushed the throttle a little to much . was havn so muuch fun . till tried to put her back in newtral .
Victor J
If you are lucky, it's the linkage on top of the engine. If not, it's the linkage down in the outdrive, and the boat will need to come out of the water to fix it.
It has happened to me twice. On my old 342, the linkage inside the outdrive corroded and broke (I had to haul the boat). On my current boat, the linkage op top of the engine came loose (easy fix).
