Waste tank location 1989 250 Fiesta Vee
dan4307
Member Posts: 4 ✭
I am hoping someone can help me determine (1) if the 1989 250 Fiesta Vee had a waste tank originally, (2) if so where is it located.
I know it is not in the engine compartment, as I recently removed the entire fresh water tank and it is a single tank and definitely not waste. The previous owner had a porta potty setting in the bath, but neither the 0.75" inlet or the 1.5" outlet was connected nor was the pota potty attached. There is another post (https://rinkerboats.vanillaforums.com/discussion/comment/24465#Comment_24465) that has a picture that looks exactly the same). Any chance there is a holding tank under the raised portion of the bath floor directly under where the toilet will attach (see picture).
I will tear into it this weekend, but was hoping someone could just tell me.
Thanks so much!!!
This first picture is the set up I have (minus the attached toilet)
The second picture is what I have.
Thanks so much!!!
http://www.amazon.com/Dometic-Sanitation-DOMETIC-PORTABLE-PARCHMENT/dp/B00PA4025E/ref=sr_1_18?s=automotive&ie=UTF8&qid=1461973440&sr=1-18&keywords=marine+toilet
The circled area on the side of the boat is the pump out connector at the top and vent below, the one below the water line is the sink drain.
The circle above the Rinker name is the vent for the fresh water tank.
