Stuck gear lube drain plug
chamberbchamberb Posts: 265 ✭✭✭
My bottom drain plug in Bravo III will not turn out by hand. I am leery of using heat. Some online sources reccomend an impact screwdriver. Any thoughts?
  • zaverin1zaverin1 Posts: 1,672 ✭✭✭
    Yes impact will work great. Had to do my port drive this early spring like that from previous owner. Make sure you take a small pin and remove any paint or gunk around the drain.
    Then use a large flat bit and pound that sucker out. Replace port and side drain plugs and put all new gaskets on the drains.
    X2 on the impact screwdriver.
    And vents gaskets also
    sorry
    I've used impact screwdriver with great success on that same plug.  I bought the cheap one from harbor freight and also used on a buddy's drive with no issues.
  • chamberbchamberb Posts: 265 ✭✭✭
    Excellent! Thank you all. I just didn't want to break it off in there. Thanks again!
    ..... I don't know how to close this or mark it Answered.
    edited April 2016
    chamberb I will close this for you. Only moderators can close a discussion. As far as "Answered" if you put your posts under "General Boating Questions" then when it gets answered the site will automatically answer it. Send me a PM if you have any questions.
    Ahh... Thanks Ray!
    Your welcome bro. I will close it now....
This discussion has been closed.
