**HELP** Engine Compartment taking on water. 1st day in the water ***
NeilBrown
Member Posts: 6 ✭
Hey All -We just attempted to get our boat in the harbor today and shortly after turning on the engine ... the bilge started pumping more water out than we have ever seem before. We checked the engine compartment and there seemed to be a leak underneath the engine - but couldn't see exactly where the water was spewing from.
We took a video with our phone ( that I can't attach to this forum) - but since this is a Sunday, will not be able to get in touch with the marina service dept. until tomorrow. Was hoping someone might have an idea of what is going on here ( Could this have been caused during the winterization process?)
Thanks!
Other possibility is your below are leaking.
Check your raw water hoses are good too.
We took it out of the water as soon as we saw what was going on so it's sitting safely in the parking lot until we can figure it out.
I live in the land of freeze and 99% of the time when a "freeze" plug (which as Al said isn't a freeze plug) pops the block is cracked....and as BD stated it is usually bad. That doesn't mean your block is cracked but having a block plug pop just means a block plug popped - little else.
If your block is cracked it can be welded. I have seen it done and last, But if the engine were mine I would demand a new block. IMO if you have a mended block your re-sale will suffer.
Good luck!
