Rinker Wiring Standard?
does Rinker use a wiring standard? If so, which one and for how long? What was the previous standard?
example: Brown w/ yellow tracer usually equals illumination (brown) and switched/outside power (yellow tracer)...
I'm looking for a method to madness, and hopes that the electrical engineer there was a reasonable fella...
it's humorous, but it's a true story:
Fact: There are 20 Wiring Standards...
Thoughtful engineer: "I shall standardize this crap"
Fact: There are now 21 Wiring Standards...
Thoughtful engineer.......................
Fact: There are now 22.....
Black or Yellow - DC Negative conductor
Green or Green w/yellow stripe - DC grounding conductor
Light blue- Oil pressure
Dark blue - Cabin & instrument lights
Brown - Generator armature/pumps
Gray - Navigation lights/ Tachometer
Orange - Accessory feed/common feed
Pink - fuel gauge
Purple - Ignition/instrument feed
Brown w/yellow strips - Bilge blowers
Yellow wRed stripes - starting circut
Tan - Water temperature
Green w/ white stripe - Tilt down/ or trim in
Blue/ w white stripe - tilt up and / or trim out
https://www.ezacdc.com/Scripts/wire-color.htm
