2008TrailMaster Rear Brake/Turn Help
elarson5757elarson5757 Member Posts: 232 ✭✭
Guys
This is one of the two rear main brake/turn//driving lights off my 2007 TrailMaster trailer for my Rinker.
The bulb is out...I can see thru the lens that the bulb popped as it's got a black mark on the glass BUT..
I can't get the dam thing open???  No tabs to press, no buttons to push, and the bulb doesn't twist and come out the back, etc.
how the (;@($:(&&&) do you get it open?  **** I thought maybe it was a sealed unit and you have to buy the whole thing but it doesn't even have a part number on it.
  • seadogsseadogs Member Posts: 66 ✭✭
    they are sealed. If its rubber mounted you can get them cheap at walmart. I keep one as a spare.
    It probably is a sealed unit. You might look on Trailmaster Boat Trailers website. I attached a link. Look in the maintenance category they will show the brands of different parts on your trailer, probably Optronics or Wesbar. This light looks fairly universal so other manufacturers probably make them as well. Try NAPA or auto parts store or local trailer dealer.
    http://trailmastertrailers.com/
  • elarson5757elarson5757 Member Posts: 232 ✭✭
    All set...didn't realize they were so common that AutoZone had them. Got one to replace and and for a spare!!
    Thanks all!!
