Trailer Bearing...
Well some of you may have seen my post the other day that after towing the boat a short distance I arrived home to hear grease boiling and steam/smoke coming off one side of the front axle on the trailer.
I've worked on plenty of cars over the year but it looks like this "washer" has tabs and you bend one up into the slot on the nut instead of the old school cotter pin.
Well the tab that WAS bent up into the nut was broken off and the nut was literally just finger tight on the axle. The spring was also out of the rear seal and grease was pushed out the back. Bearings are also very work but nothing scored or destroyed.
Just st gotten get parts and reassemble...how tightly do you make these nuts upon reassembly! Just until you can been the full tab up into an available slot? How tight should you go to get to the next tab slot on the nut?
I am adding a link to Trailmaster trailer axle maintenance manual. It outlines wheel bearing tightening procedure.
http://www.trailmastertrailers.com/pdf/axis_manual.pdf
