Cockpit table mounting flange
I am hoping this is an easy one. Perhaps a link from The Great Boomer within the hour.
I have a 2005 270 that I bought used. It came with the pole for the cockpit table but no table (actually two poles, one for the V-berth table and one for the missing cockpit table I assume). The factory table is kind of crummy as I have read. So I am looking to make a custom hardwood one but need the mounting flange.
My searches haven't come up with the right one. Any suggestions where to buy it? Thanks a bunch guys and gals.
Springfield Marine Scratch and Dent Items<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
1 Stowable Table Mount @ $10.70 = $10.70
1 Stowable Table Floor Base @ $13.75 = $13.75
We purchased the teak table from Defender
Thanks for the comments -
The table is from http://www.defender.com/product.jsp?path=-1|7504|877003&id=1584921
Half Ellipse with Compass Rose Design
Dimensions: 22.8 Inches Wide X 36.6 Inches Long, 5/8 Inches Thick
Constructed from 100% Plantation Teak
We ordered the flange/mount from Springfield - and also ordered the 30 inch pole (from iboats I believe)
1 Stowable Table Floor Base @ $13.75 = $13.75 (needed the 3 1/2 whole saw to drill into the floor) we left the other mount from the plastic table. (we wanted the table alittle taller then the normal 27 inch pole ) and moved it alittle in so the table could be centered.
5 coats of Teak Oil and it looks awesome
I would recommend to order atleast the stowable table mount and then see if you can still use your same pole and mount. You could also try one of the poles in the cabin as I believe it might be 30 inches as well - so play with what you have first before purchasing the extra pole and floor base mount. Good luck!
Old Dog......
I am going to try and post a pic. Type ur message and then click on attach a file at bottom left under diolog box and get the file from ur hard drive. We will see if that works.
Len
Len & Robyn 342 FV Freebird
Old Dog....
Looks like it worked just like I said. Its real easy and don't need imageshack or photobucket.
Len
Very Nice
2007 Rinker 280 EC , Volvo Penta GI-H , Generator
