Engine Anodes
aero3113aero3113 Member Posts: 9,863 ✭✭✭✭✭
My last boat had a Merc 470 and had one anode in the exchanger (fresh water cooled). Does anyone know if my Merc 5.7 in my 242 has any anodes in it? (Raw water cooled)
    Nope and your 2nd post is deleted
  • aero3113aero3113 Member Posts: 9,863 ✭✭✭✭✭
    edited May 2013
    Thanks Boomer, can I delete my own post or can a Moderator only do that?
    I think Capn' Steve set it up the other day where you can delete your own post run your mouse to the right by the little square and see if a little gear shows up there are commands when you click the gear.
    It might be because I'm on an I pad but the gear only lets me edit the post not delete it.
    aero when you cllick on the gear does it say "edit delete"?
    No, when I click on it it just says "edit"
    OK that is a question for Capt Steve....
    Hey aero...checking on this tonight. I can see all the functionality from the gear button from my iPad, so it may be a restriction for some reason.
    Now all members have Edit & Delete on your personal post Thank You Capn' Steve
    It looks like I now have a full functioning gear button now :)
