Mercruiser 4.3 main water pump replacement
noticed few water drops on main pulley.
looked closer and realized I have a drip coming from the engine water pump.
is it pretty straight forward removal and install. Don't need to screw with timing chain cover. Engine is 1995.
@zaverin1....really nice clean looking boat! I like the color of your canvas! That's a cool arch too!
Oh yeah!!!!! Just noticed that snubber line - best way to avoid cleat and gel coat damage plus a whole lot calmer to have a drink on the boat or sleep on it!
I loved my snubbers. Once slip mates saw what they did for my boat they were all buying them. Not cheap but SUPER effective..... straight A - full marks for you!
hose will be fixed by the marina unlike my boat.
so I played around with tilex
and mr clean scrub.
wet the seat
spray tilex and scrub
then wash down the seat let it dry and. Apply conditioner.
i will probably have to do it few more times but not like the first scrub lol.
still have to do the L seat. Then onto the cabin lol.
i am glad this boat will be stored in the building and no more shrink. You get dust but no mildew.
clr didn't work and all other products had no effect.
all forums and profesional scrubbers told me to try tilex. Key was to keep it wet and scrub. You also have to wash down the seat or surface your working on to get tilex and dirt off.
i also need to remove the external garmin GPS antenna. My GPS works fine without it and it's from a older setup so won't work anyway.
i will also look at the wire going to oil pressure sensor.
pump is a ok.!
