u013 310 EC Shore power shows 110v on a/c gauge but 0v on 110v shore power
gtyeegtyee Member Posts: 168 ✭✭✭
two cords for shore power, both good but I don't show any power to 110v system only 110 v to a/c. Tried different station to no avail. Had to have my radio amp replaced and wonder if they unplugged something or is there an additional fuse somewhere. when I use generator both work fine.. Any ideas
  • JstewJstew Member Posts: 65 ✭✭
    Did you check the breakers on the dock?  Mine has separate breakers for my AC cord and the shore power cord.  So one could be on and one tripped.
  • gtyeegtyee Member Posts: 168 ✭✭✭
    Breakers on shore are good and so are the cords as I switched them with the same results
    Do you have a separate breaker for the AC and 110V mains at shore (I have one between the aft benches on starboard for instance).
  • HamdogHamdog Member Posts: 247 ✭✭
    It might be the actual receptical that you plug the cord into on the boat. I would check that the wiring is still good.
