Rinker 370 with warning signal on pertrol/Gas
jlee432jlee432 Member Posts: 3
Hi, my name jae who bought used rinker 370 6 months ago from US and now it is in my hometown, Korea. It did have bits of mechanical issues and been fixed by mechanics here in Korea. I am using this boat like once in a month and gas is full. I recently noticed that whenever I accelerate, the monitor with information shows signal low gas. This only happens when I accelerate and gas signal become full.
It is really difficult to find someone with information here in Korea. So please kindly let me know why and how can I fix this.
Thank you and have a nice day.
  • aero3113aero3113 Member Posts: 9,863 ✭✭✭✭✭
    WoW, Korea! Welcome to the forum! I'm sure you will get any answers you need on this forum.
  • LaReaLaRea Member, Moderator Posts: 8,072 mod
    Which engine package do you have - Mercruiser or Volvo-Penta?  And which system is giving you the message?
    Does the boat still run okay while you are getting the message?  Maybe you just have a faulty tank sensor.
  • jlee432jlee432 Member Posts: 3
    Thank you for the answer. It is mercuriser and how do I get tank sensor fixed?
    Welcome to the forum.  What type of system are you having the fuel issue with?  Is it Vessel view?  is the issue just with one tank?  If it looks like a sensor, you could swap between tanks to verify the problem first.
    Thank you for the comment. Both tanks shoe low gas signal. It happens when ever I accelerate and stops once I stop in a marina. Fuel gauge goes up slowly to where it should be.
    Those things are all about resistance,  and I wager share a common ground... make sure they're well grounded without corrosion or loose.
