The radio in our Rinker will not work. Last year it was working fine. The light on the dashboard shows that there is power. Any suggestions? Could it be a fuse? I so, where would the fuse be located?
Funny story....same thing happened to me a few years ago during spring startup. Turns out the separate ground wire at the battery didn't get hooked up when the battery was installed. The separate wire fell behind the battery.
Check the obvious stuff first.....check for any disconnected wires at the battery.
Mark
2019 MTX20 Extreme
