How to remove aft thrust hub from prop
MDboater
Member Posts: 298 ✭✭✭
I removed my Bravo 3 props today and found the aft thrust hub stuck in the aft prop. I tried to pull it out with my fingers but it wouldn't move. Any suggestion for removing it?
Thanks,
MDboater
Thanks,
MDboater
Best Answer
MDboater
I used a punch and hammer to gently tap from the inside aft end. After 3 or 4 light taps the thrust hub released from the prop. No damage to the thrust hub. In retrospect I should have used something plastic instead of the steel punch.
