Adding USB outlets at the 120VAC plugs
went to replace my outlets today with ones that have built in USB charging ports. For some unknown reason the outlet is riveted to the box, not screwed on. That's a first for me, I'll have to rivet the new ones in too: no threaded part to use. Anyone know what rivet to use?  My 1/8" ones are too big, the ones used on the boat have a large head on them too.
    edited June 2016
    DB could you use a sheetrock screw? That is what is normally used when the 6-32 strips out...........
    I have a scar on my left index finger from trying to drill out one of those rivets with a dull bit. I used an 1/8th inch bit, so it made the hole that size and that is what size rivet I used to put the outlet back in.
