Bravo III paint/corrosion
Up until 2 seasons ago, never had a spot of corrosion on my outdrives, blew an outdrive and had them both overhauled and added drive showers. After that season corrosion all over the place..had it fixed/repainted, added a galvanic isolator, got a reference electrode and the Mercathode voltage was right in range, replaced both trim tab actuators (one was cracked..thought it was the corrosion source). Pulled last fall..paint peeled off, lots of bubbles under the paint, but no obvious corrosion even under the bubbles.
So sanding and refinishing again, this time doing it myself with POR-15. Could the drive showers be adding enough stainless to cause this? other thoughts for peeling/blistering paint?
I tried POR 15 once, It all peeled off within a few weeks. I have since went back to Zinc oxide for the primer and Catalized Phantom black for drive paint. Good luck but I will not go back to POR 15 again. Let me know if it works for ya though. Al
