bouncing rpms on 1 engine
captpaul
Posts: 41 ✭✭
2005 fiesta vee 300 with twin merc and bravo 3's...gets up on plane at 3200-3300rpm with no problem. as crusing, port engine rpm drops off approx 300-350rpm for 20-30 seconds and them re-surges back to desired rpm. this happens every couple of minutes. this does not occur at lower rpms...runs steady at desired rpm. fuel filters all clean and no alarm beeps. any thoughts....
get a gauge on the offending engines fuel rail and monitor if there is a drop in pressure when this occurs. it should be steady throughout range.
