Weird behavior - can't shut off 1 engine, have to shut both off.
Stodge
Posts: 2,738 ✭✭✭✭
So this is a weird one. I went to start the engines the other day. Then got an alarm from VesselView saying the drive fluid was low. No problem, I got a tube of lower end lube and added it to the bottle. This was with the engines both running. The alarm stopped. Everything happy. Then I tried to shut off one engine. Turn off key, no effect. Turn key back to on position, turn other key off. No effect, both engines still running. Turn both keys off, both engines stop. I have since restarted and tried this to the same end. When both engines are running, I have to turn off both keys to get them to stop but can not stop one or the either one at a time.
Thoughts?
Thoughts?
maybe they share a ground wire or something is shorting them out
I leaning toward haunted.
Thanks Al
Still keeping the holy water as an option though....
Please keep us updated as this is really interesting.
Really thinking the boat is haunted.
Or something got messed up when the new starter solenoids were installed.
my boats dash was not only ripped apart by someone that had zero mechanical skills but wiring was a
So, now I have to dig into the dash and see what was done versus what was supposed to be done. I have a feeling that a multi-ignition adapter was not put in. I have to count junction boxes too.
This could solve a couple issues. The good news is that the adapter is under $30.
Mine is a 2002 when Smartcraft was new.
Easy fix to add the second junction box, connection cable and the dual engine output harness.
FWIW. I have a few extra termination caps if anyone needs some.
