Marine Air systems fault code- HPF
I have been getting the fault code of HPF (high freon pressure) . Marine air system s says the internal condenser coil needs clean with a product called Barnicle Buster, or just miratic acid product like On OFF haul cleaner. The fan would not kick on and I would just have to turn unit off and the back on. Strainer is clean and unit pumps water fine. I ran a half gallon of On Off and let it sit for a few hours, and the good news was the fan kicked on and boat cooled down in minutes. Then the bad news I still get the fault code HPF. I did notice the stream of water pumping out is different. I think I defiantly loosened some gunt that was in the unit, and I'm going to try another half gallon. I used a funnel to pump the product in before strainer assembly. Any other thoughts? What are others doing to clean the internal parts. And the filter and outside coils fins are clean.
