Wiring diagram for battery charger/isolator/house battery/cranking batteries?
CTerrySGD
Member Posts: 18 ✭✭
Hi Everyone! New to the forum. Thanks for having me!
I have a 2007 300EC with Volvo Penta 305's. Had to have a new battery charger and batteries installed (2 cranking and 1 house) at the end of last year. This year I haven't been able to get anything to run the way she used to. I'm constantly seeing lower voltages on my gauges (cranking and house) then I ever did before. Mechanic said that both alternators weren't charging so he hooked them up so both would contribute etc.... Started the season and would see 11.7v - 12.2v after leaving the charger go for days. Called them and they tweaked something and now I'm seeing 12.8 and dropping to 12.5v while cruising.
I'm done letting someone else figure this out for me. I'm going to re-build the wiring as it should be so I know everything is right and all of the wiring and connectors are good. Would like to also add a 2nd house battery and inverter in the future.
I know I'm asking for a lot here so this is my basic question. Does anyone have schematic that would match what I'm trying to accomplish so I can start tracing down the problem. Going to get new batteries again so I can rule them out and the charger they installed last year is a ProMariner ProSport 20 Plus. If that's junk or not right for my application, please let me know. If you have time to add any comments about adding the 2nd house battery and/or inverter, please let me know :-)
Going to be systematically switching all light fixtures out to LED's so that will keep the load down on the house battery. Just did the NAV lights and now I'm turning my attention on the house lights.
Thanks so much! I promise to contribute to the forum with my progress and plenty of future posts that I can help with.
Chris
Chris
2007 300 EC
Welcome to this forum. I have a 2007 300 express with Mercruiser 5.0 MPI. And I do have the complete wiring diagram from Rinker, and also the wiring diagram from Mercruiser .
i do not know the difference between your 300 EC and my model, but on my boat I do not have a battery isolator of any kind but the wiring diagram that was send to me by Randy Rinker those show one, the diagram is about 20 pages long.You could try o contact Rinker and ask them to send it to you for your model.
thanks for the Infos
Paul
Paul
Thks
Paul
Chris
have a look at this for Infos on isolators....
http://www.pbase.com/mainecruising/galvanic_isolator
Measuring at the battery itself is kinda hard while running as I would only be able to measure idle. I don't have separate gear selection and throttle.... All one level on my boat. Would have to connect some better wires to the battery and run up into the cockpit to measure with any real load on the engines.
Thanks for any advice you have!
As far as checking the batt voltage while running, just start the engine and bring it up to about 1500 rpm then check the volts. you dont have to be on plane.
Tested Guest battery isolator and found the problem. It's not passing any voltage across the terminals. Tried to find the same replacement part (Guest 2403) and it will take 10 days from manufacturer blah blah so ordered a newer digital version which is apparently "Smart". No voltage loss across the terminals like the older diode style and will apparently act more like a battery charger and sense which batteries need a charge and regulate accordingly. It's a ProMariner ProIsoCharge 2 Alt/ 4 Bank which is nice because now I can add an additional bank if I want in the future. So now I'll have working alternators, new batteries, new battery charger and new isolator. Will probably go off the deep end and replace cables and connectors all heat shrinked etc in the process. I tend to over engineer things.
Quick question... Any reason I can't remove the engine start battery lines off the output side of the regulator and jump them onto the input side coming from each motor? That would at least charge my start batteries while running right? Temporary fix until the new isolator comes in and I can install. It requires two additional "key on" wires that I'll have to track down to energize the unit.
Anyway.... Hopefully this will get me back up and running. Annoying running at night and worrying about turning lights and things on to conserve batteries because alt is charging the batteries while running.
In the process of all of this noticed that my Galvonic Isolator behind the circuit panel doesn't seem to be working either. Still have yet to test, but the LED's that are supposed to be lit are not on and I'm in the mood of replacing things so I ordered a new 60 amp ProMariner and seems like a simple two wire install. Hopefully I don't mess that up but sometimes when you think it will be easy, that's the hardest install of the season :-)
Thanks for all of the help and wanted to give everyone an update.
Chris
if you can't get the wiring diagram from Rinker I could try to fax mine,since I could not the
PDF when it was send to me a few years ago. Let me know.
Paul
Paul,
After realizing when reading the manual that I'd need to upgrade all of the DC engine bay wires to 1 gauge or 0 gauge wires I decided that was a winter project. I like the idea of this isolator and the fact that it can pour both alternators into one battery if the other two are topped off, but don't want to re-wire the entire engine bay while the boat is in the water.
So I searched some more online and found an analog diode based direct replacement isolator. Decided that this would be the best option for now.
http://www.arcomarine.com/xhtml/Pages 60-62 Battery Isolators.pdf
Should be here Friday and we'll give her a whirl.....
Just giving my Rinker peeps an update :-)
I didn't forgot your wiring schematic, it would be tomorrow or Tuesday
Paul
I just send you a PM.
Paul
