Which impeller for Kohler 5KW genset?
CaptainDPCaptainDP Member Posts: 14 ✭✭
I have a 2000 Fiesta Vee 340. The impeller went out on the Kohler 5KW genset. I'm trying to find the proper replacement but my mechanic cannot locate the model or serial number for the genset even after removing the sound cover. Kohler is no help without the serial #. I contacted Rinker, but they have lost the build records. The probable impeller seems to be the Sierra 23-3314. Can anyone confirm?
Best Answer
  • CaptainDPCaptainDP Member Posts: 14 ✭✭
    That's the one I thought was probably it. Thank you!
    Make sure you get all the pieces out. They will go into the heat exchanger and causevan over temp. Pull the anode out of the heat exchanger and they will flush out.
