I have a 2007 Rinker Express Cruiser
i cannot locate the trim tabs pump. It is not in the spot where the manual says it should be. Even running the pump, I could not locate it. Anyone have an answer?
Best Answers
  • raybo3raybo3 Administrator Posts: 5,586 admin
    Answer ✓
    Most likely they are Lenco and Lenco are electric and there isn't a pump. Each cylinder has an electric motor in them.
    correct. What does the dash display look like?
  • rasburyrasbury Member Posts: 8,835 ✭✭✭✭✭
    Two controls on the rh side of your gauge panel...
    Greg, when did they start to be auto retracting when you turn the key off? Wondering if my 2006 is the same.
    If you hear a motor run for a brief second when you turn off the key, they retract. One way to check is put the key in the run position, then move the tabs all the way to the bow down position, then turn off the key. You will notice them retracting. My boat was built in 07 and it has the feature. Not sure of the year when they started it.
    edited August 2016
    Yes my 05 does the auto retract too........although I thought I read somewhere that this feature is only on the control panels with the leds? I think some just have the black buttons with no leds to show position.
    Just ordered new Led upgrade switch kit. Hope it has that option. Old one was black button"s with no indentation of where trim tabs were at.
    Mine don't show unless it's dark....you pretty much get a feel for them anyway.
