Problem with trim indicator
DazeOffDazeOff Member Posts: 164 ✭✭✭
Looking for a little guidance. My trim indicator is bouncing up and down when I trim the drive up or down. Within a few seconds it returns to it's proper position. Is this an indication of a bad trim sensor on the drive or the gauge at the helm? The drive is working fine, it's just the needle jumping all over the place that has me concerned.
2003, 270FV with bravo 3.
Thanks in advance.
    Mine was doing that and it was the trim sensor
    @BellevilleMXZ:  What was the fix?  Adjustment or replacement?  Cost?   I assume the boat needs to be out of the water.
    My 2003 270FV just started doing the same thing.  The needle is correct at all the way down and all the way up but bounces in transition between the two.
  • DazeOffDazeOff Member Posts: 164 ✭✭✭
    If it's the sensor, from what I've read, the drive needs to be removed to swap out both the sensor and limiter because of the wiring. They come as a set for under $100 for the parts. Much more affordable to do the job over the winter when the  drive comes off anyway.
    Sensors are easy to replace, the two screws that hold the sensors in place would be probably seize use a small hand impact driver to try to remove them. The worst part is the the bolts that hold the wiring harness rubber grommet into the boat, with the bell housing in place it is tricky to remove and installed back need extension and universal joint attached to your ratchet.
    good luck
    I am splicing mine in with heat shrink fittings and then I will paint on liquid electric tape
    edited August 2016
    Are you sure Steve? I hate splices in wet areas.
    I'm with Michael T, don't want to splice if I don't have to. The drive is coming off when I winterize any way, so I'll just have it done then.
    There is no voltage on these things, only resistance. It will be fine.
  • sethman919sethman919 Member Posts: 16 ✭
    edited August 2016
    The needle on my 99 Captiva was doing the same thing.  I was able to replace just the rotor inside the trim sender and it works perfectly now.  The rotor was only $16 and took 10 minutes to replace.
    edited August 2016
    Replaced it over the winter. And yes, can't see it being done without pulling drive, its a tight spot.....I didn't splice either.
    @sethman919 do you still have a part number or link to where you bought it from?
    AL, brutal, but hilariously funny. Let me guess Steve's response........
    Really, AL, REALLY? Why is everyone picking on me?
    Is that about right? Really?
    Actually it came loose and got crushed when drive was trimmed up and down. I only hit bottom in my pontoon boat
    edited August 2016
    Your skeg and prop came loose? Geez Steve, are those Yanmar products too?...... LOL
    Wrong again MT. Geeez
    It must always be pick on Handy day around here, but he has the diesel's so it's justified.....LOL.. B)
    At least I reimburse for shipping Patrick!!!!!!
    SOrry for the delay.
    Mercury / Quicksilver 805134A 4 Power Trim Rotor Kit Sender
    I just replaced mine, spliced it in with heat shrink connectors and painted on liquid electric tape. Works good
    Yeah, for 10 minutes!
    Is yours a B3 drive and was is on port or starboard side?
    Thx Again
    No, mine is a Alpha 1.  i'm sure its the same one, but double check.  mine is on the starboard side.
    I can say that splicing never works or should say works for one season or less
