Anti-glare mats for helm
LaRea
Member, Moderator Posts: 8,075 mod
In some sun conditions, my helm has a lot of glare on the inside of the windshield because of the white gelcoat forward of the helm. So I cut two small, custom-fitted carpets that do a great job of cutting down the glare.
I typically use them only on long cruises where eye strain is more of an issue. I can put them up in about 30 seconds, and they make a huge difference. When I'm not using them, I roll them up and stash them under the helm seat.
The material is just a cheap Walmart area rug (around $20). It's a navy blue Berber with a thick, relatively stiff rubber non-slip backing to keep it from blowing around. Obviously, the darker, the better.
I think the original rug was 2'x4'. First, I cut it in half lengthwise. Then, with the bound edges facing towards the stern, I trimmed each piece to match the curvature of the windshield. I also made cutouts for the windshield supports. Then, along all of the cut edges, I used a torch to slightly melt the edges so the fibers won't unravel. I've been using them for a couple years, and they are holding up well.
To cut the curved edges, I used short pieces of electrical tape to mark the contour, and then cut it with scissors.
A 1-piece design would probably work just as well, and would avoid having a seam at the windshield walk-through. On the other hand, the 2-piece design might be a little easier to set up and take down.
