Shore power and battery
I have a fiesta 250 (2004) I plugged in my shore power but does not light up my panel switch does not stat on no lights also attempted to start boat only makes a rapid clicking sound starter does not engage. Is they a overload switch or breaker I should set
thanks
thanks
i not going to question Why?
Just came from visiting my 2005 fiesta 250 after a few months of neglect. Nothing electrical works...blower, lights,etc.
When I turn on shore power switch I get a green light and the gauge goes up to about 80. If I turn on any other breaker switch, the shore power light goes off and the gauge drops to zero. An example is...with the shore power on I then turn on the fridge...shore power light goes out andd the fridge does not go on. And, of course if I turn off the shore power breaker everything is dead.
Where do I start looking?
Thanks
Of course I will test the plug connections as you suggest Duane, but shouldn't the gauge read like "pass,fail"? I mean power or no power. I don' t see how a connection can reduce the voltage.
Also, isn't it kinda mysterious that all of the power drops and the light goes off when I turn another breaker on?
I understand the voltage drop but what explains the light going out and the voltage going to zero when I turn on something else?
