Its true.... condensation happens
SeaHare
Posts: 194 ✭✭✭
The weather here in Wisconsin has been cool and windy for the better part of 6 weeks now and we havent been on the boat for a month. Yesterday I stopped by the boat just to fire up the engines and genny to let run up to temp and stretch their legs a little.
I fired up the port motor and genny and all was well, ran about 20 mins or so. Then I fired the SB motor and it began stumbling and died after about 5 mins. I checked the fuel/water seperater and it was full of water. So, i ran to the store and picked up a few new separators, prefilled one with gas and installed it on the SB motor.
The motor Fired up and ran great, i started buttoning things up thinking its all good when the motor died again and would not start. (ran good off the gas i prefilled in the filter) I checked the separator and again, it was full of water.
So, long story short, i removed the metal gas line from the carb and hose clamped a clear tube about 3 feet long to it and pumped out about 4 gals of gas/water mixture before just pure gas started coming. I took a few samples afterwards and its definitely water free. I figure about 1/2 gal of water was removed. I then replaced Filter/separator, and all is well again.
Lesson learned, the boat only had about 1/8 of a tank left. I cant let it get that low again. I figured the season was close to being over and didnt feel like filling. After owning boats for over 15 years, ive never had this happen. I though i was immune
01 FV 310, 5.7s carbed, B3s
Max temp during the day: 79 F
Relative humidity: 100%
Empty volume of tank: 100 gallons
All water condensed from the air into the tank each day
1 cooling cycle each day
30 days
I just hope the tank isnt compromised...that would suck!! Not even gonna consider that yet..
I wasn't explicit on this point but I didn't make my assumptions to show the likely ambient conditions. Rather, I used these values as extreme worst cases to show that 1/2 gallon of water in the gas tank could not be explained by condensation during a 30 day period.
