replacement stereo amps
there are so many amps out there it drives me crazy. I have a 2005 captiva 212 rx-1 that I replaced my original amp the 1st season I had this boat, it was already 5- 6 years old, so I purchased a exact replacement which is about 3yrs old and half the amp doesn't work. I'm looking to upgrade now but I don't want to spend a lot since they only last 2 yrs. I have 7 speakers so I'm looking for a 6 channel (4 channels to run the 6 interior 6 1/2" and the last 2 channels bridged for subwoofer). what brand do you guys run? my setup is a sony head unit and speakers which are now 4 sonys and 2 mtxs with 1 kicker 10" sub which I think is going. any input and info would help my deciding on which amp will work. the ones I'm looking at have some good reviews and some bad reviews..... PLEASE HELP!!!!
Secondly, amplifiers are sensitive to moisture, (even marine rated ones) and vibration, most boat manufacturers do not take this into account when choosing a location to mount it. When I had my 22' bowrider I found a location under the dash but mounted it on the TOP section so the amp itself was upside down then used a closed cell foam pad and some rubber mounting spacers under the amp (between the boat and the amp) to reduce the vibration and or bouncing that might occur on a smaller boat. It had lasted almost four years when I sold the boat.
