New to forum and new to Rinker
Chris79
Member Posts: 16 ✭✭
Hello everyone!
I purchased a 1997 Festiva 212 cuddy with the 5.7 Merc over the summer, and have been very happy with it so far. It's a great handling boat with plenty of power. Just a few questions.....
I've replaced the four speakers and head unit, but would like to still add a subwoofer. Has anyone installed one on this boat? Location recommendations?
Looking to add LED strip lighting under the gunwales for ambient light. Nothing flashy, but the one "courtesy light" in the riser of the bottom stair up to the top of the bow doesn't provide much light (also looking for recommendations on a replacement for that light, as well). Has anyone done this that could share some advice?
Also, the cockpit is mostly covered in conventional marine carpet, except for the 12 inches or so up front by the door to the cuddy and the dash, then it's just bare fiberglass (there are snaps too where I imagine there were small pieces of snap in carpet at one time. Between the carpeted are and the bare fiberglass, there's this really thick transition piece or threshold. Has anyone else addressed this? That strip just so happens to be right where you stand when driving the boat and after a while it's really hard/on the feet.
Now on to the OEM cooler for this boat. It's been asked a lot for newer boats, but not this one. I have the corner pieces still mounted to the floor and the top cushion but wondered if anyone had the specifics on the actual cooler and how the top cushion actually secures to the top of the cooler. I would of assumed it used snaps or something but the bottom of the cushion has no snaps, straps, or even a raised edge to keep it from flying off.
Last, but not least I just want to know if there are any specific known problems I should look out for or upgrades I need to make for this specific boat. It was already upgraded to a two battery system and was really taken care of over the last 19 years. I'd like to keep this for 3-4 years before we upgrade to a small cruiser!
Thanks!
Thanks!
Your cooler, sorry but it will be tough to find one on that old of Rinker, measure the space, try and find one at walmart, as close as you can get.
Nice looking boat.
Another friend of mine had that same boat, but with the sport interior. I never understood the seam where the captains seat is at. I could only figure that with the cuddy, it is a 2 piece interior mold and that is where they are put together. That seam does suck. I remember driving his boat with no shoes on and you stand right on that seam. Maybe if you changed the seat to one with a flip up bolster, it might put you behind the seam.
Cableguy - Good thought on the subwoofer placement, I had the same one at first. The problem is that the two back speakers are mounted into the board back underneath both seats. I might be out of luck. Right now I'm running 4 brand new Marine Polk Audio 6 1/2's with a 4-channel 875w 4-channel amp and it sounds great, it's just missing the low end.
One thought of the overcoming the trim piece on the floor is to buy one of those really thick kitchen fatigue floor mats and cutting a "channel" in the bottom of it to fit over the big hump. This would kind of flatten out the surface.
@Chris79,
I had the 1998 212 cuddy. It was my 1st dip into the Rinker brand. The cooler it came with did not work very well & when any sat on while underway usually ended up on the floor. The boat had lots of power & was great for water sports. But my biggest complaint was the seam in the floor, it did make it kinda awkward to stand.
I didn’t do any upgrades, only had it 3 seasons, but sometimes I do miss the simplicity of the boat.
Congratulation on the boat
While I didn't get a boat with all the different creature comforts, I am fortunate enough to have a portable thru-hatch A/C unit for next season!
Here is the 212 right before our trip to Lake Cumberland, 2010
Then a year later, same trip with the 242
This is our 342 with his new (non-Rinker) little brother.
@Glassguy54, The Tahoe didn.t do too bad, I was squezzing it pretty hard when we went to Cumberland, with the hills. We did end up getting a Silverado 1500,
