can I buy a new waste tank from Rinker, 2002 342
good day, I recently checked my waste tank and it is cracked, I am trying to order one from Rinker but I cannot get through, can someone help.
Best Answers
  • bigmikebigmike Member Posts: 9
    Thank you every body, I am in contact with Rinker and if the price is good I will buy, if not canus plastic in Ottawa could probably make one. this forum is fantastic, I HAVE THE SAME PROBLEM with my engines as another owner, I am anxious to get in the conversation. thanks again,
    Welcome to the forum @bigmike!  Some great people on here always ready to help out.  When you get a moment, add your boating location and a signature with your boat and engines.  It just makes answering questions easier and it's always fun to see where people boat.
    Why not see if "Canus Plastic" can fix your tank. It would be a lot cheaper and you know it will fit perfect when you put it back in...........
    I bought my replacement tanks (100 gallon) from a houseboat manufacturer (used to be Thoroughbred) new for $125. Be sure they are thick enough.
  • ItzkenItzken Member Posts: 34 ✭✭
    Try this link.   http://www.toddusa.com/water-holding-tanks.aspx
    Measure your tank, establish where you want the hoses, and order on the internet.  I replaced an aluminum holding tank with one of these Todd tanks in a '94 Celebrity because the aluminum failed.  Get nipple kits from any marine supply, use teflon tape and fresh hoses.
