Winterizing water system and jabsco toilet
This is our first winterizing on our 2005 rinker 282 bowrider
Need suggestions on how to winterize the water system and the jabsco toilet
Anyone know where both seacocks are for the toilet?
  • howardramshowardrams Posts: 223 ✭✭✭
    Pump out the head at a marina, drain the freshwater tank, open the seacock when you're out of the water (they'll be located right above the intake in the hull).  Mine only has the one for the head and another for the air conditioning. Put pink antifreeze in the water tank and run your pump to make it come out all the sinks and transom wash down hose.  If it's the manual pump Jabsco put some pink in the bowl and pump it through to the holding tank as well.  Doesn't sound like you have a hot water tank or air conditioning to worry about.
    Many you tube videos about it.
