concerns with new 260
It is a new 2013 260, with 6.2 liter bravo 3. It has a generator approx full tank of gas, 20 gallons of water. 4 adults on board. Still breaking engine in with approx 6 hours on engine. Haven't gone to wide open throtle yet waiting for tne 10 hours on engine first.
Problem need trim tabs all the way down and engine all the way down. takes a while to plane. Once it planes need to keep tabs at leas half way down.
If I get around 4000 RPMS it starts to porpoise. Inless I lower the trim table and get the engine trimmed all the way in. I thought the larger engine would solve these types of problems.
Any Ideas Oh yes no other weight other than life jackets on board.
Also note you should not go to WOT until after 20 hours of break in.
Mark only have 6 hours I havent opend her up but concernd witht he porposing at around 4ooo rpms. I wont be able to tell until the engine is broken in and I can do a WOT to see what the rpms are. A lttle disappointed. I had a 270 with a 350 mag and it preformed excelent. Now Ihave a boat a little shorter and not as wide I thought it would be ok. I am going to call the dealer tomorrow.
I had WOT at 4800 rpms canvas up except stern was removed.Also the center isenglas rolled up. 1/2 tank of fuel mabe 10 gallons of waterand had the center isenglas open. two people on board. It is a 6..2 with genny. However I need to use trim tabs to keep the bown down. The operating range is 4800 to 5200 RPMS.
Do I need to put more weight in the bow. Will this help? This is a 2013 that has 6 hours on the engine.
I need full trim and engine trim to get her to plane.
The Dealer is Happy Days Boating in Port Clinton they have been accomadating but I thought I should get better performance than I am getting. My 270 with the 350 did a much better job than this one. so far. Hopefully something simple can be done so I can take at least 4 adults out on a cruise.
Al when you are metioning "Stick" are you refering to the outdrive indicator? Also what isa wdge that you mention to add to the tabs?
Would it help if I added weight to the bow under the front cushion of the v berth?
If I get a proper with a lower pitch will that help. It will give me higher RPMs. It was inland lake virtually no chop almost flat
Mike T
Are you talking about the connections closet to the transom or the other connections at the other end.. by doing this does it cause anything to wear out quicker or is it just a normal adjustment ring.
If the boat is that new I wouldn't be messing with anything. Back to the dealer and let them figure it out. That is the point of buying new.
If you are out of the water, this whole thing is less than an hour to do both, maybe even faster. Note you do have to take off both black plastic caps and both nuts off the shaft connecting the rams at the drive end. The shaft is stepped down for the threaded portion and a washer is on either side of the ram connection. You might need a soft mallet or some wood to tap the long shaft out. Once you have one ram off, you will see the 'quarter moon' looking spacer, it needs to be TOWARDS the boat.
Look at this: http://www.tsgmarine.no/deler/manualer/drev/bravo/2%20Removal,%20Installation%20and%20Adjustments.pdf
Spacer looks like this:
Ok heres where we are with this one. I had a 22 inch or it could have been a 22.5 hard to see in the water. WOT still 4700- 4800 42 mph. Terrible at plaing with 2 on board. Dealer just sent me a 20.5 in prop set I will install sometime this week depending on the weather lots wind and thunderstorms passing thorough. I have my fingers crossed. not looking to top end speeds just want to be able to plane with 4 to 5 people on board and enjoy my boat. Rinker suggested the prop so hopefully it will be the correct one.
I keep you all posted until this is corrected.
Were you able to get 300 to 400 RPMS? .
I do not know what props I had on my 342 but I never had a problem getting it on plane.
I received the props this afternoon and I am planing on installing them tomorrow. I was relly excited but really hoping this will take care of the problem.
Thanks for the information
I took of the 22.5 propset and installed a 20.0 propset. Took it straight to the marina without check out the performance because of a major storm front came through willcheck it out later this week.
The nun for the forward prop was near impossible to remove, I used the mercruiser tool and needed a impact air gun to get it off. It is a lock nut with plastic threads toward the ends. It was nuts is this normal to remove the large nut. I couldn't believe. I even checked to make sure it wasn't cross threaded.
Anyway it is on and I am anxious to test the new props out. Oh yes they are provided by Rinker. They have been great fixing a few of the problems I have encountered.
