is my toilet installed correctly
rasbury
Member Posts: 8,898 ✭✭✭✭✭
I have one of the manual factory toilets and frankly, don't like it. I have rebuilt it with new seals and the famous jake valve, but looking how it is installed, the line goes up before it goes down to the tank right there in the bathroom- I don't see any way the thing can possibly pump out that bad stuff without some of it coming back into the toilet, what am I missing?
Best Answers
BellevilleMXZ
Member Posts: 732 ✭✭✭
Well the joker valve keeps it from coming back in. Mine looks the same, but works fine. I replaced the whole thing last winter, old one was getting rough looking, and complete wasn't that bad a price.2005 Rinker 270 FV Volvo Penta 5.7Gi -
Liberty44140
Member Posts: 4,414 ✭✭✭✭✭
There is supposed to be a high loop. Here is the typical install diagram. Here are some reasons that it may be coming back in to the toilet: Bad Joker Valve, Holding Tank Air Vent is not letting air in to tank, full tank, clog in the line from toilet to tank. I had backup in to the bowl when I first got my 342. Was both a bad joker and a kink in the air vent line cutting off air to the tank. Fixed both, all good.
07' Cruisers 390 (Previous Rinker's: 06' 342EC & 01' 310FV) -
rasbury
That is my set up @Liberty44140 so I guess I need to rebuild again. It just did not make sense to pump up hill without a large supply of fresh water and a limited space to store it. Will try that again! Thanks all as always. Will be at the marina and it works ok- I can tell from pump out it does vent and I have a horrible story of getting caught with a full tank- I do recall instance of stuff, paper, getting stuck for a bit... -
rasbury
Well, more issue than I thought.while heading into the marina, thought I'd pump out before I parked it, could not get anything out.had not had it out since July so figured I must have pumped? Then I notice my bilge came on.it never comes on. My tank is leaking. I know my vent is working, have never had it suck in while pumping so surprised it has somehow failed. Yuk. -
Liberty44140
Ahh bummer! Can you get to it to see if and where it's leaking?07' Cruisers 390 (Previous Rinker's: 06' 342EC & 01' 310FV) -
Michael T
Member Posts: 7,241 ✭✭✭✭✭
To eradicate any possible smell I recommend hydrogen peroxide as it "eats" biologics like blood etc. I'd use 3% weight to volume and probably 4 to 6 500 ml bottles. I'd clean the bilge as clean as I could get it then pour or spray the HP from all directions and let it drain right out the bilge drain hole. Good luck, not a pleasant task. -
Cableguy Greg Member Posts: 5,075 ✭✭✭✭✭
You will get water from the end of the boot. When the drive moves up, down, left, right it moves the shift cable in the boot. I used a zip tie the last time I did a shift boot and it worked fine for years. Be sure to use a black zip tie because they are more UV protected. The white ones break down outside very quickly.
Oh man Ras, sorry to hear about that. Hopefully you'll be able to get in there and figure it out without too much cost. Please keep us up to date and hopefully we can help you out.
here is how to do one. Some poeples use a ty-wrap if you go this way make sure that the locking pin on the ty -wrap is SS or plastic.
