Isolator project
onislandtime
Member Posts: 309 ✭✭✭
Whats your recommendation on a Isolator for a Rinker342?
onislandtime
The isolator is a box with several screw posts. Heavy, usually red, wires with caps will be attached to it. Should be at least 5 posts, 2 for input and 3 for output.
You may have a bad isolator. Easy test, check the voltage at the house batteries with the engines off and again with them on.
An isolator looks like this:
http://rinkerboats.vanillaforums.com/discussion/849/battery-charging
Blue Sea System Battery Switch ACR - Portland Marine Electronics
