Lenco Trim Tab Actuator
One of the Lenco electric trim tab actuators stopped working on my 2009 Rinker 320 EC last summer. Replacing the actuator is on my list of things to do to the boat this winter. I want to buy a new actuator but dont know which one to order. I don't see any identifying numbers or markings on the part. Does anyone on the forum know how I determine what actuator to buy? Also, the replacement procedure looks to be pretty simple, but I welcome advice from anyone who has changed one of these in the past.
http://www.ebay.com/itm/Lenco-30007-001D-Key-Pad-for-all-Indicator-Trim-Tab-Switches-w-nylon-nuts-/262716024700?hash=item3d2b18677c:g:NVcAAOSwgmJX1EmA&vxp=mtr
http://www.ebay.com/itm/Lenco-Tactile-Trim-Tab-Switch-Kit-w-LED-Indicator-15070-001-For-12-24-Volt-MD-/121754803367?hash=item1c5926dca7:g:-QEAAOSwiYFXJ44f&vxp=mtr
The starboard actuator would not stroke so I pretty much just gave it a good solid wack and tried it again and it worked :-)
As I mentioned, this was the beginning of the 2015 season and it has worked fine the last 2 seasons.
Just an FYI - on my 2003 270, I was (due to poor troubleshooting skills with electric actuators) convinced that the brain box that controls the actuator was fried since I figured that it couldn't be the actuator - the actuator has seals, and at that time, I didn't know about the Rinker forum that existed before this one.
So, I bought the brain box only to connect it up and find that it was in fact the starboard actuator. I took it off - pulled it apart and sure enough, water intrusion.
I replaced the actuator with no issues. I also learned that the port actuator is controlled by the starboard helm switch and the starboard actuator is controlled by the port switch - it sounds backwards but that is how they work.
From the Lenco Switch Operation Guide:
Switch Operation
The operation of all Lenco switches is based on the position of the bow. To lower the starboard bow, press the right (starboard) side of the switch where it reads Down. This lowers the port tab. To lower the port bow, press the left (port) side of the switch where it reads Down. This lowers the starboard tab.http://www.ebay.com/itm/Lenco-101-Standard-Actuator-12-Volt-w-6-wire-leads-/251417204000?hash=item3a89a21520:m:mrQvixLpxxv-Zz-UkVUj1hw&vxp=mtr
@randy56, Thank you! That is what I meant to say, that I am going to replace the entire actuator. The link you sent is very helpful. I will compare the dimensions of the actuator shown in the link you sent to the one on my boat. If they are the same (I'm pretty sure they are) I will know what to order.
