Kohler 5E
I need to replaced heat exchanger and thermostat, is this difficult to do?
    We have a couple K 5 expert's on here they will chime in. welcome to the forum.
  • rasburyrasbury Member Posts: 8,958 ✭✭✭✭✭
    Would not think so but why di you need to replace?
    Depending on your access, not overly difficult, very messy (anti-freeze all over). Some of the bolts are a challenge to get too also. Worth having some of the ratchet type box end wrenches.
    For the thermostat you also need the o-rings.
    Aside from some choice words, the big challenge is to purge the air out when refilling. I posted an easy how-to on here. If you get air trapped it WILL shut down from an overheat sensor.
    Best place for parts:
    www.partsfortechs.com
