deck drainage
have a 266 and the foreward deck drainage goes straight into the bilge, is this correct or can I move it to run out the side next to the shower and sink outlets?
Best Answer
MarkB
Member Posts: 4,005 ✭✭✭✭✭
Yeah, I wouldn't want a reason for water to go into the bilge. You sure a hose didn't come loose off a through hull drain?Boat Name: King Kong
thanks guys, yes it is the cockpit drainage. it simply has a pipe that ends just above the bilge pump. I thought it should run out the side too. I will deal with it. thanks again.
