rebuilding brake calipers
rasbury
Member Posts: 8,992 ✭✭✭✭✭
I got today my rebuild kits. I did just the dust boot covers when I first got the boat. This time I got a complete rebuilt kit which uses the caliper housing- everything else is new, so I get a new caliper for 30.00 bucks. I was surprised when I found the dust cover seals I had just installed, the lip had cracked letting water in and crudding everything up. The new ones don't seem to have that lip and just fits in the hole so maybe I got the wrong ones before from a local shop . Anyway, it seems to be a great complicated process to get the seal seated in the groove in the piston- have not tried to install yet, but looks like I could put the seal on the piston and then push the piston in and seat the seal in the housing? Not sure why it would be such a deal? @212rowboat might have more info as he seems to know his way around a trailer!
Ras,
Your issues sound like mine and is why I bought the new calipers with pads. Easy R & R then bleed air. No issues since and great brakes. If you've had piston and seal issues you probably have uneven pad wear (inner vs outer) like I did, even though you replaced parts a couple years ago. If you put a value on time and frustration, it usually means spending more upfront and less time and being **** that the problem came back. Hope you get it solved. Having good brakes will make you feel more confident while towing.
Ras,
To me it sounds like floater212 is putting new parts on his surge break actuator on the hitch.
