Bravo Three X Seacore to Bravo Three X
Hello,
I have a few questions about BRAVO Three X Seacore drives.
I had an accident with my boat and I‘ve damaged the drives of the boat irreparable. It is impossible to find used BRAVO Three X Seacore drives near to me.
So I would like to ask, does it is possible to use Bravo Three X type drives (without Seacore) instead of my Bravo Three X Seacore (number OW971028)? If the answer is positive, then second question is if it will be bolt on or I will have to change transom or some others drive’s parts?
I’m using my boat in fresh water, so I assume that Seacore system is not necessary, or I’m thinking wrong?
 Thank you for your help!
 JH
  • bry1429bry1429 Posts: 371 ✭✭✭
    Very sorry to hear of your unfortunate event.  I'm hoping this replacement would be covered under an insurance claim seeing how it was an accident??
    I understand the Seacore is a much more expensive unit and is built to withstand  corrosion , I would think the 2 are not just bolt up changeable . Probably needing some other components also changed. . (Just a guess)
    X 2 what bry1429 said , where is near me? welcome to the fourm
    Welcome to the forum. @Alswagg should be able to give you a better answer. He is our resident mechanic guru. We all trust him on here.
    HI Jason23, could you update your profile so we all could best help with any issues or questions.  Is helpful knowing (location,body of water, boat model,engine model & size,drives, etc)
  • Jason23Jason23 Posts: 15
    Thanks all.
    Sorry but insurance not pay :(, it's problem in Eu :). I try write to @Alswagg
    Thanks
