spot light
rasbury
Member Posts: 8,876 ✭✭✭✭✭
Dang, light works, goes back and forth but not up and down....what's up with that? Where do I start?
rasbury
most of the time the dang motor goes out and you are sol.
Buy a new or used one that works
I removed the light from the boat and disassembled it. I used jumpers to connect each motor to a 12v bat. Each motor worked, so it was not the motors. While apart I will replace the rubber boot. Next after reassembly I will install and hook up the switch to see if it works. If the switch does not make it move in both directions then I can only assume the switch is bad. Will know is a couple weeks after I get a chance to reinstall on the boat.
Also while I had it apart there is a spring that apparently helps one of the motors return to a fixed point. That spring looked broken so I put a bend in it, drilled a hole in the arm it would normally attach to and put the end of the spring in the hole.
Since there are no diagrams for this level of assembly I can only assume I did the right thing.
Andy
