Duo Prop Removal
Bayrunner
Member Posts: 177 ✭✭✭
Can someone let me know the tools required to remove the props from a Mercruiser Bravo III.
Best Answers
frenchship
Member Posts: 1,079 ✭✭✭
This is for the foward large nut,and the smaller nut on Amazon.comBuy the selected items together- This item:OEM Mercruiser Bravo III Prop Tool 91-805457T 1 $62.06
Bayrunner
Thanks for the info. Really appreciate it.Bayrunner -- FV312 - Simple Pleasure -
Cableguy Greg Member Posts: 5,072 ✭✭✭✭✭
The 2x4 is a must. Make sure you grease the shaft before putting the props back on.2008 280 Express Cruiser, 6.2MPI, B3, Pittsburgh, PA "Blue Ayes" (Sold)
Go Steelers!!! -
Bayrunner
I pulled my props off over the weekend. Using a 4 foot 2x3 everything worked fine and had no problems. The bearings were clogged with old dry lube and took a wire brush and cleaned the brass bearing until they looked brand new. Polished the props and they too look shiny. Know I have to clean the shaft removing the old lube and adding new lube. BTW; I used a pipe wrench to remove the 2 3/4" nut securing the inner prop. I just cover it with duct tape before using the pipe wrench. No problems.Bayrunner -- FV312 - Simple Pleasure
I ordered a manual from boats.net using the serial number of my drive, plugged into the Mercury Parts finder site to get the proper manual. It looks like @califco has a PDF version.
https://d3gqux9sl0z33u.cloudfront.net/AA/AR/wetbristol/downloads/224963/Bravo_stern_drives.pdf
