2006 300 EC Wiring Diagram(s)?
RustySRustyS Member Posts: 83 ✭✭
Getting prepared for Spring and want to go through the wiring in engine compartment for better understanding of things.
Diagram Request #1: I'm not for sure if there are any issues but some things seem odd...diagrams from battery switch panel including House Systems breaker(s) down to bus bars and eventually the battery connections is desired as I think some of the loads are combined that shouldn't be.
Diagram Request #2: Boat doesn't have a genny, but appears to be wired for it as the breaker is in place inside cabin on distribution panel. Thinking about purchase of a smaller 2000w inverter and changing out the existing batteries to 31 series AGM.I would like to know which wires in the large bundle going around bulkhead would be used so I can tie the inverter into this.
Diagram Request #3: As well, I currently have 1 house and 2 starting batteries. Plan would be to replace all 3 of these as described above, and place a 2nd 31 series AGM for the house/inverter supply. I'm pretty sure that is an easy addition. Planning to upgrade the charger from present 30 amp to a newer unit designed for AGM charging. What would be the recommendation; should I keep inverter and charger separate or go to a combined unit?
We have a Sam's Club close by and their AGM batteries come with some recommendations and will probably be my choice. Budget is around $2,500 for batteries, charger, and inverter and installation.
I have read through most every thread on this forum and am finding all the information very useful! There have been some topics above covered but not to the degree of my needs.
Any help and/or suggestions is appreciated! Thanks!
    I am not sure where the genny is set in this particular boat, but on mine, it was centered in front of the engine. Look for a split loom with a boat 120VAC wire (it will have a white, black and green wire in a white sheeth) tied off outside of the main larger split loom harness. There will also be another group of wires next to it with a molex plug containing a grey with black tracer and a yellow with a red tracer. That is the start switch that is on your AC panel in the cabin.
    As far as your charger goes, Progressive Dynamics makes a nice charger. Their new chargers are programmable for AGM, Lead Acid and Gel Cell batteries. The PD2120 or PD2130 would both work great.
  • RustySRustyS Member Posts: 83 ✭✭
    Thanks @Cableguy Greg; that information about the wiring is exactly what I was looking for! I'm pretty sure that's where the genny would sit on this boat.
    And I have a PD charger. pretty sure it is a 30 amp unit. It is not programmable for different types of batteries, but after speaking with PD on their helpline they give me comfort using this charger for AGM will be ok. Their rates seem acceptable to standard AGMs.
    And @frenchship came through today with a source for all wiring diagrams. I have since had contact with this individual and received the complete set; very nice and a big thanks to him!
    The only thing remaining is to figure out the wiring diagram for the 2nd house bank battery. Pretty sure this will be easy but if anyone has a pic of their battery bank with 2 starting batteries and 2-battery house bank I would appreciate it! I am wiring to a stock 3-wire isolator.
    Has been a great day for information! Cheers to you all!
    Just make sure that your house batteries are properly wired together
    That is great that you got the diagrams. One thing to ask of you, would you be kind enough to post them in the RBO Forum Archives section of the forum to help others with the same boat out?
    Greg, I just send you a PM
    Thanks @frenchship.
    I have seen this before and I intend to use this method. I am looking for some more information showing the whole scenario: want to see + and - wires to batteries (1 port start, 1 starboard start, and 2-battery house bank), isolator, charger, to-be-installed inverter, and switches.
    If anyone can provide this I would be most thankful!
    The schematics that you received shows everything that was installed at factory in details, the rest is DIY stuff.
    Understood; but I bet somebody has done this and/or could offer some guidance.
    Are you sure that you want to install an inverter... In this case you would need a large house bank batteries. What do you expect to used your inverted for? If you don't have a generator already installed. You would be ahead installing a small generator (Honda type) that what I did on mine. To see my installation do a search in the forum about generator..
    http://rinkerboats.vanillaforums.com/discussion/comment/48022#Comment_48022
    For the isolator have a look at this site. And they great at answering questions that you may have.
    https://youtu.be/B4830QsybbM
    I'm not looking to install a very large inverter; only 1,800 or 2,000 watt unit. Fully aware of your installation with the Honda unit; quite clever....but not what I'm looking for. Want a simple "flip the switch" setup for minimal needs. Battery bank will be a pair of series 31AGM batteries as I have stated. Just want some 110v convenience while overnighting on the hook.
    I have the stock isolator already in play and am aware of the functionality of the device; but thanks for the video.
    Guess I will figure this out with assistance of a marina if nobody has any pics.
    Thank you for your help so far @frenchship!
  • srlamansrlaman Member Posts: 23 ✭✭
    Rusty...did you ever get what you were looking for?  I have the same questions.  Want to replace the factory charger with a 2000w inverter/charger.  need to know how to wire the 12v side with the stock isolator and battery disconnects.  running 2 group 31 AGM's for the house bank #2 and 1 starter battery for the starter motor #1. the 110v side is pretty self explanatory...using the genny pre wire to feed the electric panel in the cabin in the genny mode.  any help is appreciated
    No @srlaman I haven't.
    This next weekend I hope to uncover her and get started on some items.
    I thought of the combo unit you are suggesting. Existing charger will seemingly be adequate for charging I am told. Once on boat I need to verify it is a 30 amp and if so I will leave it and purchase just an inverter.
    If you have stock isolator, stock charger, existing house battery, and existing starter battery 12v wiring should remain the same with connections/disconnects I believe. But I know how you feel "wanting to see" how it is done.
    I will be employing a professional when I change out and add the 2nd house battery and hook up the inverter. With all of the possibilities of wiring something incorrectly it will give me peace of mind.
    Good luck to you!
