Proper voltage readings
MajorAppealMajorAppeal Member Posts: 81 ✭✭
Hello All, I recently purchased a 270 and was making some repairs. Replaced the fuel sending unit and compass.  I noticed both read about 5 volts on a voltmeter (light on compass and fuel sending unit). Is this normal or should it be reading 12v?
    I think Its resistance only and I don't think there should be any voltage on a fuel sender. I could be wrong though. Check the ground
  • MajorAppealMajorAppeal Member Posts: 81 ✭✭
    That reading is from testing the volt reading between the ground and the pink wire connection post on the sending unit. What about the lighting? I noticed the compass light wire is very thin, is that to provide resistance?
    On the compass wires toggle the "panel dim" switch up/down to see if the voltage changes(might be dimmed down so you'll read a lower voltage).
    As for the fuel sender, you should be reading resistance across the studs(as the float rises/lowers the resistance changes)
  • Cableguy GregCableguy Greg Member Posts: 5,071 ✭✭✭✭✭
    The sending unit on the fuel tank is measured in resistance (ohms). It should read 240 ohms empty and 33 ohms on full.
