Gear lube fitting at transom
At end of last season I lost all oil out of port reservoir (I shut motor down immediately ) when pulled out at end of season I saw that the fitting is broken Where the hose connects at the transom anyone know how hard this is to change on the 2002 342? Can it be done from outside?
2002 Rinker FV 342
Oh ReneeChris! Every time I see that picture I cringe!
Bella, yes you have to remove it from inside, and definitely very tight and tough to get to.
@bella-vita the drive and the bell housing must come off to access the tube.the tube slides in from outside and the clip on the inside.
