Gear Lube Reservoir
Cableguy GregCableguy Greg Member Posts: 5,077 ✭✭✭✭✭
What do you guys use to clean out the gear lube reservoir? Mine has sludge in the bottom of it and I would like to get it cleaned before my lower unit comes back from repair.
    Brake cleaner.
    Did you have a lot of sludge?
    It is about 1/4" thick. I have never cleaned it.
    Be careful when cleaning the reservoir.  If you have a rag or anything inside the reservoir anywhere near the float pin assembly it is easy to dislodge and if you do it can not be repaired. You'll have to buy a new one. There is an E clip holding the float onto the ss slide pin that can come off rather easily. Don't catch anything on it or it will come off. Ask me how I know. :-( To clean them I just drained them with a turkey baster - CAREFULLY (the second time lol) with a soft lint free rag that had some new gear lube soaked into the tip - worked great and didn't introduce contaminants from another product, then refilled the reservoirs.
    Brake cleaner. Evaporates quickly
  • rasburyrasbury Member Posts: 8,965 ✭✭✭✭✭
    Why would there be that much sludge?
    The oil breaks down from sitting.
    Brake cleaner works well or mineral spirits too.
    Last yet My tanks were nasty on the bottom. I took them to work and used mineral spirits to clean them out. This season they drained normal
    and no sludge.
    its from age and not cleaning I assume
    we are dealing with gear lube oil and not something super thin
    I went the easy route... I bought a new bottle from Wholesale Marine. It cost me $41.
    I cleaned the old bottle, but I should have listened to @Michael T . I tried using Acetone, which made a real mess. Got some Mineral Spirits and it cleaned right up. Now I have an extra bottle for the next time.
    Yep I cleaned my bottles in our parts washer which runs minerals and came out great
