Help needed with 270 FV Canvas Install
gackgack Member Posts: 315 ✭✭✭
I took the day off of work today to install snaps on new canvas I purchased from TJ and ran into problems.  I installed the two bimini tops but they do not fit right with the existing poles that came with the boat. The previous owner has two biminis but no side curtains or camper canvas like I have.  Would the poles be different for a full enclosure?   Does the back pole for the front bimini go forward or aft of the radar arch?
    Don't know if this will help but, I  installed rear top, here is post.
    http://rinkerboats.vanillaforums.com/discussion/6109/installation-of-camper-top-on-270#latest
    What tj sent you is what was original from the factory. If the previous owner or before had something new or custom made it may not fit with what came from the factory. Probably best to post some pics of the situation.
    OK, think i just figured it out by googling pics of other 270s.  The poles came installed in the boat so I assumed they were in the correct position.  looking at other boats I'm pretty sure mine is wrong.  See pic.
    gack, ill take some of my top. could you shw a pic a little lower where it connects to fiberglass   that looks different from mine for sure. mine is a 2004 270fv
    Trashman, Can't get to the boat until the weekend, but here's a pic that I found online.  Looks like my pole was installed backwards by prior owner for some reason.
    Yup, mine is on backwards, an easy fix.  Was worried I had the wrong poles.
  • Cableguy GregCableguy Greg Member Posts: 5,067 ✭✭✭✭✭
    From the picture you posted above, you can see that the canvas was put up correctly, but the poles were backwards. Glad to hear that you figured it out.
    Ok,  I got my poles sorted out, now I have another question. My windscreen seemed short when trying to connect it to the windshield. I know the canvas should be tight, but I was afraid I would tear it or bend a pole if I pulled to hard.  I did some research on the issue and found that some 270s have a windscreen that slides into a track at the top of the windshield and some snap into the top of windshield (not sure what years have what).  Picture is what I got from TJ which has a rubber channel on it, is this a slide-in windscreen?  My boat has the clip-on windshield frame snaps so do I need a different part?.  Thanks for the help.
    I have snaps on my 2002
    I have snaps on 2003
    That black rubber tubing is just a gasket to keep water out, the tube does not slide in to anything, you still use snaps
    And usually the snaps do not come pre-mounted because they need to be mated to the location of the corresponding male part of the snap on the windshield frame.  They are generally in about the same place, but can vary slightly.
    edited April 2017
    I also have two "twist fasteners" (one on each side of the walk-through windshield). The help out a lot when putting the canvas on and lining everything up.... I drop my canvas into those two first and I know the rest will just snap into place.
    Post edited by diggin2day1 on
    Oops. :# sorry. Now I see in your earlier post that you were in fact.....installing snaps.
    @Willhound, yes thanks.  Piece just does not look right to me.  I had a 250FV and I recall it had the matching blue canvas where it met the top of the windshield where you would install the snaps.   This windscreen doesn't.   Just wanted to make sure before I put holes in it.  Willtake aanother look at it today. Diggin, I have the twist fasters also,  but those are at the bottom of windshield for cockpit cover.
    My cockpit cover mounts to top of windshield in same snaps as the windscreen
    Oh, ok.  Mine mounts to bottom and covers the windshield.
    OK, I got it on.  I forgot how much new canvas can stretch and was gun shy about putting holes in the canvas.  Once I got the front on, side curtains went up pretty quickly.
    Wow I can see right though it. :)
    Looks great!
    Nice! New top is so tight that even a cross bar being a half inch out causes issues. Congrats on persevering.
    Just following up with pic of camper top fully installed.  Great addition for these cool spring days and doubles the size of the cockpit.
    Awesome! Looks just like mine.  Jealous of your oversized platform though. Mine's stock and no budget this year....
  • rasburyrasbury Member Posts: 8,849 ✭✭✭✭✭
    looks great, we just completed ours late fall and yes, it "doubles' the size of the cockpit- great at the dock, like having a townhouse! Now I need to come up with a way for more privacy at the dock with it up...that does not look to tacky...but for the money, best money we spent on the boat!
