Following winter (boat out of sea) Wet carpet found at bottom of stairs on my 282 Captiva Cuddy. The boat has a sea toilet Marine Head with pump out holding tank no drawings anybody have solution ta Max
Thanks MarkB yes de-iced freezer. There is what looks like drilled hole may be drain hole for hull not sure close to where carpet is wet ? If that's where problem is how do I remove water ?
