Raw water strainer installed wrong
reneechris14reneechris14 Posts: 3,134 ✭✭✭✭✭
Fired up motors today,trouble getting port motor to prime(impeller changed last year).cleaned out strainer and the yuk was under the basket? The thru hull and the outdrive Y together and enter the strainer in the lower hole and the pump exits above the basket.I assume this is a factory install.Did not take pic's as this just sunk in after looking on the web.
notice the arrow,I think mine is backwards?
Is this the same unit you guys have?
2005 342 5.7 horizon
Best Answers
    Answer ✓
    I'll climb back in tomorrow and check again.
    This a factory install?
    @rasbury Flow probably doesn't matter when in water,but trying to run on muffs it sucks the air from the top.and stuff gets under the screen  (basket).
