110 volt fridge operation
Willhound
Member Posts: 4,243 ✭✭✭✭✭
Not sure if my Vitrifrigo fridge is operating on 110v or not. No problem on 12v with battery switch on, but if I turn battery switch off, no light in fridge even with shore power panel switch to on. Maybe only a 12v model? Or not plugged in? Don't see a switch anywhere or breaker labeled refrigerator.
normally all fridges are 12 volt with 110 automatic converter. It's all automatic and switches on its own when senses 12 or 110
you should have a plug behind the fridge
I know my boat does
which is fine if you run your battery chargers at the marina
http://www.vitrifrigofridges.co.uk/installation.htm
Definitely no breaker on the panel in the cabin.
12v breaker at the helm. Based upon the diagram on the website link above, and the pic
of my controller, looks like DC only?
Fridge is Cleary labeled for AC but looks like compressor is not. Was maybe switched out at some point?
Mechanic from dealer currently on board with me going over the snags we identified during trial. One if them us it appears the on-board charger isn't working. If we get that going, then I guess it doesn't matter. I can run it on battery/shore power.
Just back from spending 5 hours on board with mechanic from the dealer. Small miss in the engine cleared up by changing water separator and cleaning up the distributor cap and rotor, although I'll probably do the plugs , wires and distributor soon. Shower sump fixed. Freshwater pump working. On board charger was toast and electric head conversion not working, so a return visit with parts needed, but overall coming along. The hospital of buying a 17 years old boat that's sat for over a year.
The Mobiltronic unit that I listed above does the switching. You could pick one of those up. If not, when your charger is fixed, it will keep the batteries up, which run the fridge.
