toilet water source
Mercury2005
Posts: 141 ✭✭
Reading through the discussions, it seems a lot of boats use sea water to flush the toilet. It seems the boats that use sea water have a seacock in the location of the shower drain. Well my 06 270 only has one seacock and it is marked 'air conditioner'. My toilet has a blue water line going to the bottom of the toilet which leads me to believe my toilet is supplied with fresh water. Anyone out there have a similar setup?
There are two schools of thought. If the toilet is supplied by sea water, you can always flush, but sometimes the holding tank gets smelly. If the toilet is supplied by the fresh water tank, there's usually less odor, but you can't flush if your fresh water tank is empty, or if your pump quits.
Having used both, I prefer the fresh water feed.
